Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Temp Sensor
    Aug 2005
    I have seen a 1993 525i BMW M50TU. It did not have a temp sensor near the throttle body either.
    I will check the underside of my manifold if it is there (it must be there).
    VIN: GG45422
    Liverpool England
    yeah its towards the firewall pointing upwards, let me know please what you find.......
    Benneton (United Colors of)
    the thing that you show in the realoem picture and the bentley picture is not the engine coolant sensor, it is the air intake temperature sensor. your market may not have them, the m50 2.5 vanos might not have them (i have a 2.5 m50 nonvanos that does). the coolant temperature sensor is located under your intake manifold. there are two sensors, side by side. one tells the engine computer the temperature, the other tells the temperature gauge in the dash what the temperature is. are you intentionally trying to change your air intake temp sensor? or are you tyring to change one of the coolant temperature sensors for engine problems? you don't need to remove the intake manifold to change the coolant temp sensors, i did so using both regular wrenches and a flexible handle ratchet.
    Aug 2005
    I wasn't looking for the coolant temp sensor. I was looking for the intake air temp sensor. I simply noticed that I don't have it in the place that the Bentley shows it should be.
    So my engine might not have it at all?
    VIN: GG45422
    PA
    Engine has to have it - it retards ignition if IAT get too hot
    This picture shows a cut-trough view of the air-mass sensor:
    The air-mass sensor is completely electronic, no moving parts. It's also known as the hot-wire sensor. The sensor exists basically out of 2 parts: (1) is air intake temperature sensor and (2) is the heated wire.
    The hot wire is heated to 100 degrees Celsius (180 F) above incoming air temperature when the ignition is turned on. So on a hot day, if the ambient air is about 30 degrees Celsius (86 F) the hot wire is heated up to 130 degrees Celsius (266 F). It doesn't glow at that moment. When you open the throttle, intake air flows over the hot wire and cooling the wire down. With more air passing the heated wire, the cooling effect is greater. The control circuit of the MAF is trying to keep the hot wire at the same original temperature of 100 degrees Celsius above ambient temperature. So the control circuit is applying more current flowing through the heated wire. This current is measured and converted into a voltage signal, which gives the DME an indication how much air is sucked into the engine.
    That is at least how the MAF works on the 750 and on other cars which have the same MAF
    http://bmwe32.masscom.net/sean750/MA...leshooting.htm
    Aug 2005
    Bentley says that M50 uses hot wire which has a burn off cycle. and that M50TU uses hot film MAF without a burn off cycle.
    I think M50TU's do not have the temp sensor, or rely solely on the temp sensor in the MAF.
    RIPN RAY, did you mean the coolant temp sensor or the air intake temp sensor?
    VIN: GG45422
    Aug 2005
    The temp sensor is located on the underside of the intake manifold, as Ray said. Attached is the pic of the intake manifold turned upside down. Its on the upper right of the pic, with two pins.
    VIN: GG45422
  1. Outside Air Temp Sensor
    By borderchris in forum 5 Series BMW
    Last Post: 01-10-2008, 02:30 PM
  2. Sensor adjacent to temp sensor
    Last Post: 02-15-2006, 03:59 AM
  3. blue temp sensor
    By Jose in forum 5 Series BMW
    Last Post: 12-11-2005, 02:22 PM
  4. OBC Temp Sensor help
    By Rory525 in forum 5 Series BMW
    Last Post: 07-13-2005, 08:33 PM
  5. OBC and outside temp sensor retrofit.
    By Dan in NZ in forum 5 Series BMW
    Last Post: 04-27-2004, 01:25 AM
