Results 1 to 10 of 16
Thread: the oil smell like gasoline
    Default the oil smell like gasoline
    Hi,
    Own: BMW '93 520i Auto
    The oil is mixed with gasoline on the dipstick! (Gasoline in the oil)
    any help?
    Do you only drive short distances so that the engine hardly gets warm to operating temperature?
    Maybe you drive a longer distances so that the engine get's really to operating temperature and then check it again.
    I assume that it is gone then.
    Any starting or running problems? smoke on start up? Check engine light come on?
    3 most common causes are leaky injectors, faulty O2 sensor, faulty fuel pressure regulator.
    Search foum for "stomp test" and check the codes. this needs to be diagnosed asap and the oil changed, gas is very bad for bearings.
    post with further details please.
    Sep 2005
    MI
    This is true for just about all engines I believe. When starting, a little gas will slip by the rings and into the crankcase. Once the engine oil gets up to temperature, the gasoline will evaporate.
    Are there other problems you are not telling us about? Cylinder misfire, etc.
    Job 14:1 Man born of woman is of few days and full of trouble.
    az
    there is no running problems nor smoke on start up
    but I can here sound (tick tick) from air regulator even after turning the switch off
    and high gas consumption
    Maryland, Virginia, D.C.
    You need a leakdown test.
    USA
    the tick tick thing is the air ventilation control flaps and indicates a failing AC control unit.
    .. you need a leakdown test.
    I would start with diagnosing the poor economy. It could be something as simple as the plugs are totaly worn out.
    Start with the basics. check the tune up even if you put plugs in recently, escpecialy if you used bosch platinums.
    Check the codes, it may have a O2 sensor code. If it is running rich and you have no code, the sensor is probably bad. If it has a code, it may be bad plugs, bad regulator, bad sensor, or other less common problem.
    Somehow the gas is getting into the oil past the rings, either you have bad rings(not common) or you have too much fuel or poor combustion(common).
    tempe
    i bet the pcv valve is bad.
    Default Yeah,if only he had a pcv valve....unfortunately he doesn't
    Quote Originally Posted by jjdickm
  1. What Gasoline do you put in your E34?
    By Fetch in forum 5 Series BMW
    Last Post: 10-19-2006, 06:08 AM
  2. Gasoline smell at first starting
    By Al Gray in forum 5 Series BMW
    Last Post: 02-05-2006, 02:38 PM
  3. Gasoline smell
    Last Post: 01-13-2006, 12:02 AM
  4. OT: How do you get gasoline smell out of carpeting?
    Last Post: 11-03-2005, 06:53 AM
  5. Gasoline Smell
    By DMahon in forum 3 Series BMW
    Last Post: 06-11-2004, 06:31 PM
