Results 1 to 10 of 20
Thread: Trans said "E R" in 4th . . . not a good sign.
    Default Will definitely book mark the place.
    Javier
    Sep 2005
    MI
    Nice website Rustam. Unfortunately, I can't get the switch out of the center console.
    The selector switch is the off-white blob center right, below the yellow bolt. To the immediate left of the selector switch is my problem. It is an "L" shaped lever and it rides on the brass shaft below the yellow bolt. Just below the shaft you will see the topmost part of the selector switch (square-shaped) and the outside edges of another allen bolt. I think I need to remove that lever, to remove the allen bolt, to remove switch. Any thoughts?
    Job 14:1 Man born of woman is of few days and full of trouble.
    az
    Default Check your mail.
    Javier
    Sep 2005
    MI
    Thanks for the email Javier but it still doesn't solve my problem (unless I'm missing something and I probably am). Fortunately, it did give me proper vocabulary. My problem is the interlock lever. The Bentley only mentions it in passing ("for cars newer than '93 . . . "). In your picture 32 25 071, the interlock lever is riding on a shaft that has a bolt on one end. My shaft is mushroom-shaped on that side so I can't figure out how to remove it.
    I'll double check but I'm pretty sure even if I remove the entire shift lever assembly, I will be faced with the same problem, only portable.
    az
  1. Replies: 4
    Last Post: 12-31-2008, 10:41 AM
  2. 530 "bucks" or "chugs" but driveshaft feels good....
    By 300k 5er in forum 5 Series BMW
    Last Post: 10-09-2006, 02:09 PM
  3. "Trans Program"/"Limp Mode" Redline a Engine?
    By JMI in forum 5 Series BMW
    Last Post: 06-12-2006, 10:51 PM
  4. Is www.racdyn.com the "good" or "bad" Racing Dynamics
    By talltorontoguy in forum 5 Series BMW
    Last Post: 11-18-2004, 12:27 AM
