Originally Posted by
marckula
this is part of an investigation into the cause of an abnormal amount of vibration. i had the clutch replaced last month and, being a cheap-ass, i only had them resurface the flywheel. i think the flywheel is not balanced anymore so I have a new one for them to install now.
but along with this, I am trying to figure out if theres another problem, this time where the trans input shaft meets the crankshaft via the pilot bearing. when the trans shop pulled the trans to install the new clutch, they said the old pilot bearing was loose and just fell out of the crankshaft. my thought was that the pilot bearing might need to be INSIDE the pilot bushing then press-fit into the crankshaft.
