Results 1 to 10 of 18
Thread: big drop off in mpg
    Default big drop off in mpg
    91 535i auto 209k runs great -but the mpg went from 21 all the time to 16-18 after a battery change-any ideas????
    hole in the tank?
    Quote Originally Posted by diamond777
    Honolulu
    Default Filled up with E10
    mine dropped after a few tanks of that crap
    Bethlehem, PA
    The usual culprits are O2 sensor and AFM. The battery change might be a concidence, exacerbated by resetting adaptation.
    So.Calif ( L.A. Beach Area)
    are you doing mileage by the computer/tripmeter or your actual odometer mileage?
    if dojng the first I'll bet you have to recalibrate the puter
    Honolulu
    Default Could just be
    Since you'v e disconnected the battery recently, the OBC has a shorter duration and mileage data to avergae by.
    Just for fun reset AVG 2 and see how quickly your AVG MPG changes with a few stop lights and coasting down a hill.
    I know the first few hours after a disconnect, the AVG is quite sensitive to changes in driving conditions.
    Ethanol? Will reduce 10%...
    USA
    actually a 10% ethanol blend reduces mileage by about 20%.
    I would think the ecu just needs to relearn its timing adjustments again over a few dozen "warm" miles.
    Maryland, Virginia, D.C.
    Who's spiking with 10% ethanol now?
    Mar 2004
    Not quite. MPG is directly proportional to the heating value of the fuel. Gasoline is ~115,000 btu/gal, ethanol is ~77,000 btu/gal.
    (1) gallon E10 is .9*115,000 + .1* 77,000 = 111,200 btu/gal
    111,200/115,000 = 96.7%
    10% ethanol reduces mpg about 3.3%
    Paul Shovestul
    Quote Originally Posted by BillionPa
    ......actually a 10% ethanol blend reduces mileage by about 20%
  1. 535 Suspension Drop
    By aston_jag_tech in forum 5 Series BMW
    Last Post: 05-13-2010, 12:14 AM
  2. Drop it like its hot
    By ArnZ! in forum 5 Series BMW
    Last Post: 09-24-2009, 10:04 PM
  3. Volt drop vs fuel pressure drop/stumble
    Last Post: 04-24-2006, 07:06 AM
  4. So how much drop?
    By Island530i in forum 5 Series BMW
    Last Post: 02-09-2006, 03:05 PM
  5. RPM drop...
    By TETSUO in forum 5 Series BMW
    Last Post: 04-05-2004, 11:37 AM
