Results 1 to 10 of 18
Thread: Relay help needed, several things out at same time.
    Florida
    Default Relay help needed, several things out at same time.
    All at once my sun roof, the central locking system, the wiper blades, power windows and the onboard computer stop working on my 1989 535i. Is there a shared relay that may be bad, your help is needed?
    Nov 2005
    Blackpool
    Quote Originally Posted by WILLIETOPZ
    yes, under your rear seat you will find 2 long black boxes labeled RM and GM, means general module and relay module - these could be loose or faulty - try unplugging them both then after both are removed(important) plug them back in again.
    they are hidden under a plastic cover, which requires 2 screws to remove them you will have access to them
    otherwise replace them
    Default But first check if you have power at fuses F30 to F47 ...
    below back seat. If not, you probably have a bad Fuse Link (Do a search in Fuse Link for details).
    Javier
    Nov 2005
    Blackpool
    Quote Originally Posted by Javier
    Javier
    are you talking about a fusible link? the 80amp thing.. if so wouldnt that take out more than just what he mentioned?
    regards the fusible link if you want to check, its located below rear seat, opposite side to the rm boxes i mentioned, big thick red wires going into it and the cover hinges open, check the silver strip hasnt broke and power is flowing
    Florida
    The link was broken, thanks for your help!
    Default similar problem
    I am also having problems with the central locking system, wipers, sunroof and windows. I've tried replacing the fuse and it blows it out right away. Both fusable links are good. I haven't checked the general and relay modules yet. Any other suggestions.
    Thanks!!
    Jul 2004
    Quote Originally Posted by lauraseth
    Thanks!!
    low fuse rating?
    deleted air conditioning
    the fuse is 7.5
    have you used a higher rated fuse?
    USA
    stick a multimeter beween the fuse and the wire and measure the current, there may be something using way too much power.
    Wellington,New Zealand
    windows use LOTS of power i am sure they need more than a 7.5A
  1. '89 535i Relay help needed
    By Coupeowner in forum 5 Series BMW
    Last Post: 12-17-2008, 10:26 AM
  2. Time to make a choice...Car purchase help needed!
    By Alan_525i in forum 5 Series BMW
    Last Post: 04-22-2007, 03:32 PM
  3. Replies: 8
    Last Post: 07-02-2006, 07:58 PM
  4. M50 coils, main relay or fuel pump relay?
    Last Post: 05-31-2006, 07:48 PM
  5. Relay information needed urgently, please.
    By mikeyboy in forum 5 Series BMW
    Last Post: 11-13-2005, 05:55 PM
