Here's some help, compliments of Bruno's site....
http://www.bmwe34.net/e34main/mainte...oorRemoval.htm
Alright I was removing my rear door panel to fix parts that are bulging out, i pushed all of the door clips out, and took out the two screws in the ash tray and the door handle, the thing still wont come out where am i going wrong?
when removing my rear door panel. you have to remove three screws
1. door handle
2.screw behind ash tray
3.scrw inside arm rest
once you remove those the panel pulls right off
the top of the panel clips into the window sill. Start from one end of the top and yank up and out. be sure to unscrew the lock tab. When the panel is free, you will need to unfasten the cable running to the door handle.
You must lift up on the panel to release the center holding clip in the middle of the door. Up and out....
