Results 1 to 3 of 3
Thread: Blinker frequency...
    Jul 2004
    Default Blinker frequency...
    I have a question regarding blinker control. The one for left turn used to flash much more frequently than the right one. A couple of days ago I spent some time trying to see whether the transmission was connected well deciding to disconnect the "SEM" switch. Having then gone on a highway I realized that both blinkers workwed at same frequency. This actually happened once before, I don't recall having the switch out at that time. Does some one know what may be responsible for variable control of the blinker? Perhaps they should always and both flash at same rate? Does this have anything to do with sport mode?
    deleted air conditioning
    USA
    they should flash at the same rate unless one of the bulbs has different current draw than the other, then it will speed up (bulb burning out for example)
    I had a funky bulb where the deal that holds the filiment spread and did the same thing. Different brand bulbs all the way around.
    Quote Originally Posted by BillionPa
  1. Right blinker stays lit! :(
    By misfortune in forum 5 Series BMW
    Last Post: 08-24-2008, 01:26 PM
  2. Normal frequency of top-off for cooling system
    By JMI in forum 5 Series BMW
    Last Post: 12-13-2007, 11:50 AM
  3. Blinker Issue
    By e34bimmer.com in forum 5 Series BMW
    Last Post: 12-05-2007, 11:13 AM
  4. Replies: 11
    Last Post: 08-06-2005, 06:45 AM
  5. high frequency vibration
    By ocampg in forum 5 Series BMW
    Last Post: 02-04-2005, 07:18 PM
