Results 11 to 20 of 22
Thread: E34 headlight aim (screw location??)
    Feb 2005
    Penang, Malaysia
    i just removed the headlight shroud (behind the headlight, in side the engine bay). i can see the plastic part moving together when i turn the screw - i guess it shouldn't happen right - broken it seems?
    how do i take out the grill to put in the new screw? is it difficult - i hate taking things out that has plastic clips which may break
    you need a new screw,
    Headlight Adjuster Screw
    Part # : 63 12 1 378 368 $ 4.95
    http://www.bavauto.com//assets/produ...3121378368.jpg
    shouldnt break any plastic things, there are areas you will have to push with a screwdriver or something to pop the clips out of the way. There is a diagram floating around somewhere here.
    Quote Originally Posted by ktteoh
    Feb 2005
    Penang, Malaysia
    regal/shogun, i assume the approach is to leave the whole headlight assembly in place and to just take off:
    1. the headlight shroud (behind the headlight, inside the engine bay)
    2. the grill cover at the front of the headlight
    i know how to do (1) but i need clues how to do (2) correctly so that i don't break any dear old plastic clips - my dear old car is ~13 years old so things are a bit fragile .
    folks, any clues especially pictorial guidance would be most helpful.
    many thanks ahead.
    Feb 2005
    Penang, Malaysia
    folks, any pictorial clues on step (2)?
    Maryland
    To get the headlight grille off you have to remove the chrome kidneys and the steel body-colored front grill.
    Get a strong flashlight and look for the tabs holding the kidneys in.
    The steel piece is held in place by six plastic tabs on the center grille (three on top and three on bottom)
    AND it's held in place underneath the corner lights by a plastic tab on each side -- for this I recommend you remove the corner lights and get a good look at how it's held in place
    Feb 2005
    Penang, Malaysia
    folks, finally i didn't went thru the hassle of removing the front grille. instead i adjust the downward aim of my low beam by using a plier to hold the white plastic thingy still from behind the headlight and turning the screw from the front end.
    while doing that i notice that my left/right aim is off - however the plastic handle attached to that screw is broken - how do i adjust the lef-right aim then?
    i will try to snap some pictures but meanwhile i look fwd to any collective advice/experience in this area.
    Quote Originally Posted by Evan
    I assume you mean the
    Headlight Adjuster Socket - 3 required per headlight
    Part # : 63 12 1 378 369 $ 0.95
    http://www.bavauto.com//assets/produ...3121378369.jpg
    Feb 2005
    Penang, Malaysia
    Default Headlight - left & right aim adjustment
    nope. the headlight (low/high beam) aim can be adjusted for up/down & left/right.
    the screw to adjust up/down is via the 2 holes on the front grille - got that and it's perfect with my 'workaround' above
    now i want to adjust the left/right aim (horizontal aim) - i believe the screw to adjust that is behind the headlight unit (from inside the engine bay behind the plastic shroud) - it should be a white plastic handled screw but i could not see any in my car.
    Nov 2006
    Germany
    I just replaced two of the adjusters on my newly purchased 1995 525i and boy did I do it the hard way! I took out the headlight housing for easy access to the back of the adjuster when I didn't need to. I also scratched the top of the bumper with the bottom of the light assy. Bummer.
    Take the grill off to get access to the adjusters. The local dealer parts guy suggested always replacing the black cup when replacing adjusters. I fully agree as the swap is easier if you split the black cup with some diagonal cutters (two cuts, one on top and one on the bottom to split it) before removal from the headlight assy. This releases the squeeze pressure on the adjuster ball (screwdriver end), allowing a much easier dislocation of the ball head out of the black cap and then the cap out of the headlight assy. I figured this out after trying to push the black cap out of the headlight housing's ear with the ball inside it. I tried to squeeze it out with pliers, a bad move as I cracked the ear!
    Once the black cap thingy is out of the way, grab some needle nose pliers and twist the white plastic nut jobby of the adjuster from the front of the car to unlock it from the headlight assy. It should twist a quarter turn or so then release. Take it easy as the white stuff is pretty delicate.
    Installation is the reverse of disassembly, minus the cutting of the black cap. Just take care when snapping the adjuster ball into the black cap as the headlight housing is fragile!
    While you have the grill off, adjust them lights!
  10. #20
    in order to complete this thread: can someone make a pic of his U.S. headlights with the screws clearly shown and makes some arrows to show the screws and for what they are?
    This shows the EURO headlights with headlight aim motor
    http://jcrdevelopments.com/node/250?page=show
    retrofit automatic headlight adjustment is shown here from around page 50
    http://de.scribd.com/doc/80785425/4/...and-Headlights
    Maybe these pics help
    http://www.ebay.com/itm/BMW-E32-E34-...item3a7f31f7aa
  1. Vent screw / bleeder screw...
    By Rick L in forum 5 Series BMW
    Last Post: 05-25-2007, 09:46 PM
  2. Location of headlight buzzer/dinger/chime?
    By profeign in forum 5 Series BMW
    Last Post: 11-28-2005, 01:33 AM
  3. Replies: 0
    Last Post: 10-28-2004, 02:11 PM
  4. Replies: 3
    Last Post: 08-12-2004, 10:20 AM
