Originally Posted by
t_marat
Had to resurrect this post.
Every time I block this nipple, the engine stalls when at operating temps (middle of the gauge). It drives OK, but when I engage the clutch and switch to neutral, it forgets that it needs to idle, goes directly to 0. Tried doing the reset, by disconnecting the battery for the whole night. Does not help.
If I remove the blockage from the nipple and let it suck air as it wants, the engine does not stall. But it needs to be blocked, I saw another BMW 525i, and that nipple is blocked in it by a rubber cap.
Can I safely presume the issue not being the ICV? If it was ICV, should not it stall with the nipple being open?
I read somewhere about a breather valve being the culprit. What do you think?
