Follow-up questions for Jon
Jon,
I'm new to bimmer.info, but have hung out at bimmerforums for a couple years. I dug up this thread after seeing your "turbo" video. I'm planning to do a Car PC in my 90 525, and I have a million questions.
The most relevant here would be related to the climate control. I noticed that you have 2 knobs next to your screen. I assume you linked the two temp controls and did away with the dual zone feature. And I saw the A/C, Rear Defrost, and Recirc controls on the dash, but how do you adjust the airflow between defrost vents, dash vents, and floor? And if you did away with those controls, how do you set the system to defrost?
I'm curious as to what mobo, cpu, and monitor brands you're running, but that's less important now.
Do you plan to integrate an OBD scanner w/ your system? I'd like to, but am having trouble finding anything compatible with OBD-I. Are they supposed to be backward compatible? If so, I feel very stupid.
Nice job on the car all around!
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
