Results 1 to 10 of 11
Thread: PS hose questions
    Wichita, KS
    Default PS hose questions
    My hoses are leaking right at the reservoir where they connect, can I just replace the rubber parts with standard PS hose?
    Matt J.
    '95 540/6- Jim C. chip, Bilsteins, B&B, For Sale!
    -Sold
    www.wichitabmw.com
    CT
    Not sure about the hose but I had a leak that was leaking onto the air filter box between the PS reservior. Just had to tighten the clamps and no more leak.
    Wichita, KS
    Already tried that, no go. The ends of the hose are splitting, so I think it's seeping around the clamp.
    Matt J.
    -Sold
    www.wichitabmw.com
    Wichita, KS
    Anybody?
    Matt J.
    -Sold
    www.wichitabmw.com
    Nov 2005
    Sarasota, FL
    I don't know how different the 540 is, but mine had banjo fittings at the other end so I ordered it from BMA. If yours is just regular hose from the reservoir to the pump, don't see why you couldn't use it.
    91 535iA M30 Auto
    Born in 3/91 (The Bimmer, not me )
    120,000 Miles
    Pics soon--she is a work in progress
    Wichita, KS
    That's my question, I have heat shielding down there so I can't see the ends. I wanted to know if it was a connector I could tie into with a regular PS hose.
    Matt J.
    -Sold
    www.wichitabmw.com
    Why do you not look into the online parts catalog?
    I can tell you that the high pressure hoses have special bended pipes for BMW and are connected with hollow bolts. And that on both sides. Because the hoses are layed out for 200 bar!!!
    The return lines from for example the power steering pump has such a connection on one side and on the other side on the reservoir just a normal hose clamp.
    So you have to find out first if it is the high or the low pressure line.
    East Brunswick, New Jersey
    Quote Originally Posted by onewhippedpuppy
    Can you see the hose from the pile? There is a banjo bolt connection on the other end (the PS pump end). But the reservoir end is not pressurized. If you can trim the top end off and still make connection, you can save yourself some money. Otherwise you need to get one new.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Oh no..The hose (item #15)
    http://www.realoem.com/bmw/showparts...80&hg=32&fg=20
    costs $153 and change from the following link,
    http://www.trademotion.com/partlocat...gOEM&siteid=26
    If you are cheap like me and if you are reasonably handy, let me give you the following suggestion. The top connection is easy. It is just a hose clamp. The bottom connection is also not that hard. Remove the front plastic pan (four plastic nuts, 10 mm socket). Loosen and remove the banjo bolt to pull the hose (22mm or 23 mm wrench, IIRC). Bring it to a hydraulic shop (check Yahoo yellow pages for a hose shop near you). They'll scrap the rubber part, keep the metal part and make a new hose for you for under $40.
    One way or another, there is no getting around draining the Pentosin.
    '01 540it, 6/01
    '10 535ix. 9/09
    '10 mini 6 speed
    Wichita, KS
    Thanks guys. No idea how old the Pentosin is, so it may not hurt to change it anyway. Shogun, realoem is the first place I check, but on the diagram it looks as if one hose is only connected by hose clamps at both ends, I assume it's the return. Also, I've seen banjo connections with a barbed end that clamp on, I didn't know it was a crimped on one. Another project to add to the list.
    Matt J.
    -Sold
    www.wichitabmw.com
  1. What is the P# for the hose that
    By BennyM in forum 5 Series BMW
    Last Post: 08-26-2009, 09:08 PM
  2. What is this hose?
    By artguy in forum 5 Series BMW
    Last Post: 09-06-2007, 06:47 PM
  3. Where does the other end of this hose go to?
    By JD525IA in forum 5 Series BMW
    Last Post: 05-15-2007, 04:59 PM
  4. e34 m50: is my hose ok?
    By shragon in forum 5 Series BMW
    Last Post: 10-27-2005, 01:42 AM
