Originally Posted by
Bill R.
flow and pressure of the pump can just cause more heating problems rather than less. You want the water to flow through the radiator at a certain speed allowing it to transfer as much heat as possible while its in the radiator. Frequently higher volume pumps move the water through the radiator too fast , not allowing enough time to pull as much heat away from the coolant as possible. Not to mention that the more pressure and volume the pump puts out ,the more horsepower it steals from the engine to do so.
I've never had any problems here in arizona running the stock pumps and stock radiators on bmw's
