Hi all,
First of all I realize you all have covered this subject a few times but alas I have more questions. I just bought a 1990 525i with 247,000 miles. This car is amazing, runs strong. She does have a very loud valve tapping about half way down the cam. Now I realize this is common for this motor, what I am un clear on is a few other things and am curous if a valve adjustment will affect things. First of all the fuel milage is about 5mpg lower then it should be. Second, theres a small hesitation off the line at low RPMs but she takes right off after about 900RPM. Thirdly, theres a slight bit of dark smoke from the exhost when you get on it very hard also a little soot around the tailpipes almost like the timeing is off a bit. My last concern at this time is the transmission oil, instead of there being a red ATF as I'm used to theres a clear oil almost like a hydraulic oil, is this normal?
The Nube,
Josh
