Thread: Well.. I Think It's Touring Hatch Harness Time ;(
    Default Well.. I Think It's Touring Hatch Harness Time ;(
    Just got the LIC PLATE LIGHT in the check display in the gauge cluster. Rear hatch Glass (only) release has not worked in about a month or so (on the same harness?). Got the test light out (after a new license plate bulb did not cure the problem, or so I thought...). Test light got a positive signal only when I moved the rear hatch up & down... Hmmmm. I knew it was inevitable. My car just turned 191K, so I knew it would be needed sooner or later. Everything else works on the rear hatch (rear wiper, rear washer, reverse lights, 1 license plate light). I cannot complain, I love this car
    Question is, I know there are 2 rear hatch harnesses- a left & a right. Which side is needed (or should I do both while I'm in there?) I have already done the 3rd brake light (new) harness, lense assembly, etc about a year ago..
    Didn't Scott H have a real nice write up on this?
    TIA Guys-
    Don McAdams
    McAdams AutoSport
    www.McAdamsAutoSport.com
    '95 E34 525iT
    '88 E30 ///M3
    '85 E30 325e
    Vero Beach, FL
    Austin
    It's find and resolder or replace. They sell each side independently, so the choice is yours.
    fyi it's 8-12 of labor if an indy is doing it.
    If you have headlight adjusters, they throw the lic plate light error too. I gave my old harnesses to Scott H., so he'll have to tell you his success if he even got to it.
    I hvae new harnesses and both my lift switches are acting up; I think it's the actuators this time, as I cannot see any wear or unusual rubbing up in the window hinge area.
    good luck
    No, it's replace time. I saw what the wires looked like when I did the 3rd brake light harness (scary) there must have been 2-3 breaks in that wire harness, plus the wire is so brittle..... 10-12 hours! I will be doing it myself, no indy for me
    Do you know which harness controls what on the rear hatch (left or right side one)?
    TIA-
    Don McAdams
    McAdams AutoSport
    '95 E34 525iT
    '88 E30 ///M3
    '85 E30 325e
    Vero Beach, FL
    Austin
    Quote Originally Posted by Don McAdams
    TIA-
    I'll bump this in the hopes that scott will know off hand. I am sure the schema is listed in a wiring diagram. who is our resident wiring guru again?
    Default Here Don.....e-mail me offline if you need more help...
    http://www.bimmer.info/forum/showthr...touring+wiring
    it's in the second post as I could not get the PDF to embed in the first one.
    Quote Originally Posted by 530iTouring
    Thanks a lot Scott. That is a pretty nice write up. I appreciate the help! Looks like it's the right side harness....
    Don McAdams
    McAdams AutoSport
    '95 E34 525iT
    '88 E30 ///M3
    '85 E30 325e
    Vero Beach, FL
  1. Fixed all my hatch harness error messages!
    By attack eagle in forum 5 Series BMW
    Last Post: 04-15-2007, 11:34 PM
  2. I need a touring hatch for parts
    By Elekta in forum 5 Series BMW
    Last Post: 04-02-2007, 05:20 PM
  3. Touring Hatch Harness- Thanks ScottH
    By Don McAdams in forum 5 Series BMW
    Last Post: 11-05-2006, 02:39 AM
  4. Where can I buy a hatch harness for a 525i touring?
    By monkeytown in forum 5 Series BMW
    Last Post: 07-02-2006, 09:14 PM
  5. Touring hatch
    By Steve N in forum 5 Series BMW
    Last Post: 04-09-2004, 08:51 PM
