Results 1 to 2 of 2
Thread: Volt drop vs fuel pressure drop/stumble
    Apr 2004
    Default Volt drop vs fuel pressure drop/stumble
    Volt drop vs fuel pressure drop/stumble. See link from Racetronics.
    Could this be the reason for the stumble problem that we have had over the years with our '89 525a?
    Have observed stumble and coincident fuel pressure drop and test light dim with my little McGuyver test rig. Also reported on this board was Onboard Computer in test mode showing 9v coincident with stumbles.
    Early on we had problem of b+ lead to F pump backing out of big wiring harness connector under the dash. Might this intermittent connection with probable arcing have created high resistance connection that affects b+ at the fuel pump? Problem reacts positively to clean up of engine/chassis grounds and use of Stabilant to maximize connections.
    http://www.racetronix.com/Racetronix..._Pump_Kit.html
    PA
    Could be. That kit looks like it would provide a good setup to bypass the stock wiring to the fuel pump.
  1. Drop it like its hot
    By ArnZ! in forum 5 Series BMW
    Last Post: 09-24-2009, 10:04 PM
  2. big drop off in mpg
    By diamond777 in forum 5 Series BMW
    Last Post: 05-05-2006, 08:02 AM
  3. Drop Spindles?
    By afxjzs in forum 5 Series BMW
    Last Post: 04-07-2006, 04:01 PM
  4. So how much drop?
    By Island530i in forum 5 Series BMW
    Last Post: 02-09-2006, 03:05 PM
  5. RPM drop...
    By TETSUO in forum 5 Series BMW
    Last Post: 04-05-2004, 11:37 AM
