Results 1 to 9 of 9
Thread: Just put a fresh Mahle Air Filter in a wow...
    San Diego
    Default Just put a fresh Mahle Air Filter in a wow...
    Just put a fresh Mahle Air Filter in a wow did it make a difference in power. That old filter was packed full of sand and crap (2x trips to Las Vegas every month take its toll) .
    Anyone else using a Mahle filter? They are OEM replacements and my mech thinks they are excellent.
    Check out the filter test. Mahle has the least amout of air restriction to the box!
    http://www.bolhuijo.com/airflowtest/
    [2004 BMW 330i 225HP Sports Package, Steptronic Trans, Xenon Adaptive Lights
    Lexington, Kentucky
    Mann air filter was not tested. BTW, I have used Mahle and Mann and air filters and have not noticed any difference in performance between them.
    Bethlehem, PA
    Heh. I have that exact leaf blower and can testify as to how powerful and LOUD it is. Run it without ear protection and you'll be partially deaf for a couple hours.
    That's a great test and should be required reading for everyone who utters the letters K&N.
    Houston, TX
    Interesting - and just what the gurus on this forum have been saying for as long as I've been reading. There is no substitute for regualr maintenance - change that baby every year - and change the cabin filter at the same time.
    Norway
    Changing the cabin mircofilter is a hell of a job Ive heard?
    Albuquerque, NM
    Quote Originally Posted by Espen
    It's a bit of a pain but not that bad. I think for 5's you do have to remove the glovebox, but once that's out of the way, the filter change only takes 15 or 20 minutes once you've done it before.
    Here's a link for doing a 7, once you get past the glovebox removal (not included), the rest is the same:
    http://www.nmia.com/~dgnrg/page_4.htm
    gale
    Lexington, Kentucky
    I think my indy charges 45 minutes labor for the job. BTW, I have changed mine twice myself. it is much easier the second time. Do it once a year or every 15,000 miles. do not wait 30,000 miles, like me, or the air volume goes way down and the fan start to whistle at higher fan speeds.
    Houston, TX
    Just did mine - took 20 minutes, including time to search for the screw I dropped and that rolled under the car. It took me an hour my first time, but once you get hands on, you can do a lot of things by touch - like replacing the glovebox. You only need a phillips head screwdriver andf a torx driver. You'll thank yourself for doing it after you're finished.
    San Diego
    It's worth it to have your indy do it. Mine took 1/2 hr. My old cabin filter was so dirty I was getting very little air flow. After the new filter (Mann) was installed the #1 fan position blows like the #4 before I replaced the filter. Should replaced it a long time ago. What a difference it makes.
  1. Bosch or Mahle?
    By 94_e34_525i in forum 5 Series BMW
    Last Post: 07-18-2007, 05:24 PM
  2. Replies: 0
    Last Post: 11-07-2004, 10:02 PM
  3. Mann or Mahle filters
    By Sweetwater in forum 5 Series BMW
    Last Post: 09-03-2004, 10:30 AM
  4. Mahle oil filter?
    Last Post: 06-03-2004, 08:23 AM
