To clarify, I am asking if anyone has come across an 18mm nut, which based on searches does not seem to be the case...
I went on the TMS site today to order up bilstein/H&R package. When ordering, you need to specify the diameter of the bearing nut and cap. The only choices in the pull down menu are 1 1/8" and 2.5" for the dust cap cover, and 19 and 22mm for the bearing nut.
I walk out to the car, with my caliper, and find that the diameter of my dustcap is 3", and the nut is 18mm. On the phone, TMS confirmed that the measurements above are really the only options. My question to you guys: What gives? Am I measuring the right things here? The washer diameter is 2.5", so maybe they're referring to the internal diameter of the dustcap? Have any of you come across this before, or has my fast-becoming-legendary PO once again broken new ground?
Armando
the smaller is generally on the older cars, the nut size signifies the bearing hole size for the strut. I think you need to get the 19mm strut inserts but I wouldnt bet my life on it.
The cap is the inside diameter cap... so most likely you have the 2.5" one... now for using caliper on the nut... it is never right unless you go diagonaly touching two of the 6 points of the nut... not the middle flat part. So it is much easier to find the socket that fits.
You have the 19mm/1 1/8" combo. As Tiger said, drop a 19mm on it and watch the magic
Jeff, my 91 has the 22mm combo. I assumed older cars the larger ??
Anyhow,
Dave M
*RIP Oskar the DOG*
the id for the dustcap is 3" on my car and I have the 22mm nut, didnt measure it just remember its a 22.
who nailed it! There I was, trying to be smart using caliper when the easy socket-check was the way to go. Thanks to all for catching my massive brain fade - I've called every single Bilstein distributor I could think of in the last couple of hours trying to figure out what was going on!
We are so smrt
*RIP Oskar the DOG*
Question - why does it matter? If the diameter of the strut nut connector is the same, etc etc.. What is the difference between 19 and 22MM nuts?
-Artem
the size if the shaft that goes through the top strut bearing. The bilstein sports have a spacer so it will fit in both.
Originally Posted by ArtemLepilov
