Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Please help: VERY stubborn brake dust
  1. #21
    Auckland, New Zealand
    Quote Originally Posted by GS535i
    Try a spray bottle of your favourite blue glass cleaner ( eg, Windex) and a hose: wet a trial spot down well with the glass cleaner .... wait a min. or so .... and hose off.
    The mild alkaline action of the aqueous ammonia often does the trick ....
    Put some windex on it. Got a rash? Put some windex on it. Blisters? Windex.
    Freude am Fahren - Damn straight!
  2. #22
    Quote Originally Posted by uscharalph
    The Armor All wheel cleaner worked pretty well on my bottlecaps.
    Degreaser with a stiff nylon brush works very well indeed. Car washing liquid and a good rinse to get that off before it has a chance to affect the clear coat.
    A nice polish afterwards protects the surface, once it is that clean, anything will stick to it...
  3. #23
    Nov 2004
    Chevy Chase
    wheel acid, I know everyone says it damages the wheels but I have never had a problem. Dilute the stuff with water, 70% acid 30% h2o and let sit for about 10 seconds, then brush off with soapy water and a semi-stiff brush. I use this stuff called wheel wonder and it really is a wonder. I am not sure if you ca get it in small quanities, at my shop we get it in 60 gallon drums. I used it on (100% strength) a 10 year old mercedes wheel (painted and clear coated) and literally just blasted it off with a hose. AMAZING, hopefully you find something that helps, if not it's elbow grease.
  4. #24
    Jan 2005
    Kelowna, B.C., Canada
    Wheel acid does work really well but I tried it on mine and it made a mess of the polished lip, it made it very dull. Luckily I only tested it on a small section of 1 rim. We use it at work diluted 5:1 and it is amazing on painted rims as long as you rinse it all off right away but I would never use it on anything with a polished lip.
  1. Brake rotor-dust shield
    By russiankid in forum 5 Series BMW
    Last Post: 02-17-2009, 01:49 PM
  2. Low/no dust brake pads?
    By Ross in forum 5 Series BMW
    Last Post: 11-13-2007, 02:56 PM
  3. tip for keeping brake dust off wheels - thank god
    By derick in forum 5 Series BMW
    Last Post: 01-20-2006, 11:28 PM
  4. Replies: 13
    Last Post: 03-11-2005, 09:25 PM
  5. LOW (or no!) dust rear-brake combo.....
    By MO525 in forum 5 Series BMW
    Last Post: 04-05-2004, 03:33 PM
