Check control lights
Here's a check control problem I've never seen posted before:
The LCD panel in the instrument panel on the '90 535iM (for sale) has a problem. The display sometimes illuminates faintly, other times not at all. The characters on the display are active and can be seen (fasten belts, light on? etc) if I shine a torch on the display. The lamps themselves check out OK.
What module is responsible for activating the two CC light bulbs?
The SI display lights up OK on startup - it is part of the same LCD as the CC, odometer and auto trans indicator's functions. I'll double check the diagnostic mode later but I think it is dim then as well.
As the car is for sale, I don't want to spend $$ fixing but would prefer it worked as there's less for prospective buyers to gripe/negotiate.
Anthony
03/64 production
