That's salt. You will have to clean everything bare, then clean with lots of water to remove the salt from inside the door. (it comes off the glass and ends up at the bottom). Then dry fast in low humidity environment and hit with de-oxidant and rust-converter. Then undercoat and top-coats. No black metal, all shiny. It will still rust but take longer. You need to replace the door to fix it properly. Nick
