just to clarify - the manifold is not necessarily glowing... those turbos only put out about 7 or 10 psi... nothing - they are more than likely using a thermal camera that highlights the heat.
If that was IN the car... Imagine how hard you would have be fanging to get that sort of temperature
Gone but NEVER forgotten. :'(
And then...
uhhhh...you've never seen a glowing manifold! don't you have a turbo? **** my 89 760 volvo turbo would glow just from the interstate at the bottle neck before going into the turbo, after a good flog the whole turbine housing would glow, seen a late model amg benz motor on a dyno glowing the pipes back a good 10 feet
Originally Posted by Jon K
1000-1375 degrees is the range from blood to cherry red, not a big deal on a gas motor
winfred - i wasnt sure if they were actually glowing or if they used a thermal imaging camera.
to really retard the timing to prevent detonation, then its lighting on the way out... Thats how exhaust valves go bye bye
I wondered that too and that was one of the reasons I requested an explanation of what I was seeing.
I was reminded by the subject of high temperature and glowing exhaust - McLaren F1 uses gold to shield the heat from that bmw v12:
deleted air conditioning
its very likely that the engine is run at max rpm - they do that deliberately to break parts, so that they can be taken outand analyzed to design better ones...Originally Posted by BigKriss
