Originally Posted by
stargazer_61
Well, after a whole days work, I nearly have the timing chain cover off, to look and see if one of the guides broke, per Joshua's suggestion. It is not a trivial task, to say the least. Pull vibration damper and all accessories except the A/C, valve covers, drain oil, drop the frame reinforcement bracing, pull the engine compartment brace. Am in the process of dropping the oil pan, that should be the last piece before the cover comes off.
On the plus side, there is no oil starvation in the valve train, and it is extremely clean, not like those sludgy pictures Bill R posted a while back. The right bank has a bit of varnish buildup, where the left does not. Cam lobe wear looks to be normal, with only marks from the rollers. If it isn't something in the timing chain area, then it is looking like either a broken piston pin, causing slap, or a sticking valve, as has been suggested. If it is the piston, I will be in the market for a low mileage 4.6L SOHC within a days roundtrip drive.
