If your only spinning some nuts with it, get a little pancake compressor, the air tools will have the required cfm/pressure on the instructions. Air tools are meant to use impact sockets(this includes air ratchets). Impact sockets are softer so they save wear on the air tool and don't crack under use. Impact guns have a ring retainer instead of a ball retainer, using crome sockets will damage the ring retainer. Air ratchets have ball retainers so you can use the crome sockets, but it will eventualy wear out the nose on the ratchet.
Craftsmen should be fine for an air ratchet unless you have a good one from snapon or mac. Expect broken sockets from time to time with an impact.
