Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: ECU swapped, coils swapped - STILL NO IGNITION ON 4
    Aug 2005
    Newton, MA
    Default ECU swapped, coils swapped - STILL NO IGNITION ON 4
    Today i pulled everything off the engine - namely the harness will try to find a cause for the misfire problem. This really pisses me off... Does anyone know what else I can do?
    -Artem
    Nov 2004
    Winston-Salem, NC
    Quote Originally Posted by ArtemLepilov
    -Artem
    Could the spark wire be bad?
    -ashley
    Paper Gaskets Suck!
    Aug 2005
    Newton, MA
    Possibly - thats why I took the wiring harness off - im going to check and see... Unfortunately I need to do a hell of a lot of work in astronautics at the same time and ship a lot of items... This is a very very bad time for me... This week is going to be hell.
    -Artem
    Meridian, ID
    Did you try moving coil from number 4 to another cyl to see if you just have a bad coil?
    Mike Holbrook
    Meridian, Idaho
    baton rouge, loserana
    did you check that you were getting the signal to that fuel injector?, the power should be constant with the key on and the computer triggers it with a pulsed ground signal
    Aug 2005
    Newton, MA
    Are both the coil and the fuel injector work together with the same pulse at the same time?
    -Artem
    no but one can shut down the other
    -Artem
    Aug 2005
    Newton, MA
    so, when there is no continued circuit on the fuel injector, there is no spark? Is that how it works?
    -Artem
    Default I'm getting really bored with this thread so here's a few
    things that may or may not help... first off the dme won't shut off the spark to an individual cylinder if there's no continued circuit on the fuel injector.
    It has a feature in the DME known as the catalytic converter protection on your car which is dme version 3.1.
    This feature will shut off the injector to any cylinder that a fault is detected in the coil primary circuit. The later cars which have 3.3 and higher monitor the primary and secondary ignition circuit and shut down the fuel injector if needed,but yours only monitors the primary. This is to keep from dumping raw fuel into the cat.
    If you have a injector fault it won't shut down the coil since spark without fuel won't cause a cat to overheat
    Next since you have changed the dme and the coils both, have you checked for voltage at terminal 3 of the coil connector with the key on?
    All of the coils have 12v at them when the key is on and the dme makes and breaks the ground to trigger the spark. If you look at the harness you'll see that all of the coils have a junction point in the harness where they all meet for the positive supply line. If you don't have 12v at terminal 3 with the key on then back trace it and find out at what point you do.
    -Artem
    Aug 2005
    Newton, MA
    Hi Bill. I checked all the coils a while ago, as well as checking for continuity - all of the coils were getting power 12V - 13.46 to be exact. The Coils, the DME wiring is fine and the DME is fine. I can test fuel injectors while the DME is on the car.
    Meantime Im putting the harness back on the car.
    -Artem
  1. Can a E28 5 speed be swapped into a 535 E34?
    By Bruno in forum 5 Series BMW
    Last Post: 05-12-2008, 10:58 AM
  2. Swapped cluster getting ESD Regelt. Did search need help.
    By Felixdacat in forum 5 Series BMW
    Last Post: 05-13-2006, 11:42 PM
  3. Anyone swapped diff ratios for better mileage???
    By Robert K in forum 5 Series BMW
    Last Post: 08-21-2005, 10:03 AM
  4. E34 M43 - 1995 Overheating though everything swapped
    By Martin - Denmark in forum 5 Series BMW
    Last Post: 06-09-2004, 04:33 AM
  5. The 3.64lsd needs the front flange swapped.
    By Martin in Bellevue in forum 5 Series BMW
    Last Post: 03-04-2004, 10:00 AM
