Ask the same question here, there are many 750 drivers and we can help together.
http://www.bimmerboard.com/forums/e32/page/0
Some questions:
is the EML light in the dash on for about 2 seconds when you start the car (ignition in position 2).
Thereafter it should be off and never be seen during driving, otherwise the car runs in limpmode.
Can you see in the dash the selected gear mode?
The speed limiter might be out, if they also changed the chip in the EML, the chips in the 2 MOTRONICS are only for more performance. But that does not matter, speed limiter comes in at a speed more than 250 kmh.
What kind of scanner did you use?
What is the VIN number so that I can have a more detailed look into the wiring diagrams? Last 7 numbers is enough. Or Go to my website below and use the VIN decoder as I need the month and year of production (not the first registration date), to see which MOTRONIC is installed.
Do you get a warning for LAD? There is a speed limiter for the LAD in case of failure, maybe the sensor is misalligned.
Have you checked both fuel pumps if they are working?
When have you changed distributor caps and rotors?
Remove one plug from one side MAF and see if engine dies, then the other side the same procedure.
If engine dies completely, you found out that one side is not working. That is already a good starting point.
Remember that if you remove the plug from the MAF on drivers side in the engine room, actually the cylinders on the other side in the engine room are affected.
What is on the right hand side in engine room for the intake, works on left side and vice versa.
To understand this, click on the explosion view of the engine on my website below.
