Curious M50 bleeding issues - help -
I replaced the thermostat, housing, gaskets, water pump, and hoses.
I filled the resivoir with 50/50 BMW coolant and distilled water (pre-mixed) to full cold.
I put about 8 quarts of the mix in, with the top hose detached to let air out.
I then reconnected the hose, loosened the bleed screw, and started the car.
When it heated up to just over 1/2 it started spewing coolant and blowing steam from the bleed valve.
I am not used to this scenario. I have bled my M20 engines many times and dealt with only bubbled coolant escaping from the bleed valve. Never pure steam.
It appears I have *lots* of air in the system, which of course I must bleed, but the temp gets too high (3/4) if I let id go.
I have stopped for the evening and will re-bleed inthe AM.
Any ideas???
BTW, it had no cooling issues previously. I was doing preventative maint.
1995 525iT
2002 330i
E30 325iX - gone
E28 528e - gone
