OK..Just want to let you guys know..This is Don this time.. Thanks for all the help so far..it has helped me eliminate what is not causing the troubles..
To start off, Shirley was asking questions thru me..and sometimes I might not have been as easy to understand as she has no experience with mechanical issues.
The car did not run out of gas..I thought it might have due to the engine stopping.
I will start at the beginning,
1. Car sat for roughly six months..I was told car had a bad trans due to the TransProg. But I was told it ran great.
2. The Batt. was dead so I recharged it and it is holding very good charge.
3. Upon starting the engine..which took alot of cranking, it did start , ran very rough and alot of blue smoke came out with either oil or condensation out of the tailpipe.
4. Engine ran very rough..surging RPM's up and down..I tried to keep it running..but it did die. There was alot of upper noise as in the lifters or tappets..I mean alot..but I thought that was due to the car sitting. I then thought it had ran out of gas.
5. I put in 6 gallons of gas..which brought it up to over a 1/4 of a tank..and then I put in alittle more..which it now has close to 1/2 tank.
6. Continued to try to start it...but it wouldn't fire..it is getting plenty of spark...but If I leave the car turned to continuosly engage the starter..if will fire..but again run very ruff.
7. I replaced the spark plugs...which were covered in oil..on the inside..which looked as though they were fouled..and 3 of them had oil on the outside as well..with no oil present as far as a gasket leak..
8. Upon replacing the plugs...I tried to start it..and guess what..the same thing..car would not start...and then then it finally did..it runs the same way..very rough..alot of upper noise, surging...and then dead..when it dies..if I crank it it is no easier to start..
9. When it would not start, I did spray ether into the trottle body..just to see if it would fire..and it made no difference..still nothing...
10. I know there is oil..I put 2 quarts in..due to it was low, the Anti-Freeze up full, no oil in it...and no water in the oil as I see...the car seems to be getting fuel..and spark. I did check to see if the crank sensor was loose..and it is not.
11. The way I see it...if it is running and even though it's running rough..the upper end should not be noisy...as far as the rough running..I would think it is fuel delivery...possibly injectors or some electronic control.
12. As far as the trans prog...I do appreciate the info..you guys have been wonderful..as soon as this car is running properly..I will dive into that..
13. I have not done a compression check and plan on that today...
14. Now that you guys know the whole story..what gives?..Should I just drop it off at a shop..or do you guys have any other suggestions..I can rebuild Chevy's in the dark..but this has me baffled..
Thanks agin,
Don
