I made fiberglass spacers to raise the rear...Originally Posted by Felixdacat
well thats nice to know, i was just about to buy some bumpstops!
do the front struts also have them built in?
deleted air conditioning
what factory bumpstops have you removed? on the rear or the front? My rear sport bilsten did not come with bilsten built-in bump stops... I think I am misunderstanding something here...Originally Posted by Felixdacat
i think there is a misunderstanding:Originally Posted by BillionPa
front - yes built in bump stops...
rear - no built in bump stops...
My Bil's came with a diagram showing the internal design. Unfortunately I threw out the diagrams after installation. It shows a flat slight bevelled disc internally at the bottom of the shaft in the shock. I would not have removed the factory bumpstop in the rear if this was not true. I also spoke with a couple of e34 owners in the area who have the same set up, and also told me to remove the bumpstop, cause they would bottom out often. I have followed there instructions, and have not had any problems. Except for my rear camber. Hence the reason I would like to get Eibach, or another set of springs. Did you put the spacer between the upper spring mount, and the body mount assembly? And how many did you use. If this would solve my camber problem, without going stock, or getting new springs, This would be awesome.
The sports and HD rear needs the factory bumpstop, but most people cut some of the bottom off.
The sport and HD front have a built in bumpstop.
I am installing HD with Eibach springs in about a week or 2 (just removed the old rear shocks) and am ordering the last accessory hardware today.
I put the spacer between the body and the strut mount, so that the relation between the strut and the spring is not affected. I used one spacer per side, 1 and a half inch thick.Originally Posted by Felixdacat
Perhaps I should make a picture of the car and post it...
indeed. my sport bilstein came with instructions that shown how much and where to cut off the bump stop, i did just that and never experienced a problem...Originally Posted by BillionPa
however - i got the bumpstops too late I think. I once drove into a big pothole on a highway going at ~70mph. I think the rear strut bottomed out harshly - a few days later I realized that the car dropped on that rear wheel about half an inch.
I got the bumpstops to avoid breaking another strut in a bout of paranoia. I think the strut may be damaged.
so my advice - use the bump stop if bilstein says "do"...
First off I would like to say Sorry for being such a hard head about the bumstops to everybody. I did some more research, and of course I was wrong. I listen too much to what other people said to do, and wound up looking like a arse. If I ever doubt what locals say I'll have to ask the pros before anything is done. Rustham thanks for the info on the spacer. I'll give this a try this weekend, and give you an update. Thanks Derek
