Results 1 to 7 of 7
Thread: Strange AT problem
    Aug 2005
    Newton, MA
    Default Strange AT problem
    Hey - I was driving like that for a while... I got no idea whats going on there...
    This is my problem:
    When I drive my car, and let go of the accelerator, the engine's RPMs go wild - they fall to 1000 and jump back up to 1500 periodically and rhythmically... Same thing happens when i drive my car at a certain speed and trow it in neutral... I believe that shuldnt happen, should it?
    -Artem
    PS - the car was doing that before the ECU problem...
    Aug 2005
    Newton, MA
    Anybody?
    -Artem
    Aug 2005
    Newton, MA
    Thank you very much for the reply
    You think those are detached? I will check tomorrow, but im almost sure I put them on right.
    -Thank you, Artem
    Default Its more likely to be the throttle position switch on the throttle body. If it
    doesn't close the contacts for the idle position when the throttle is closed then it acts similar to what yours is doing.
    Quote Originally Posted by ArtemLepilov
    -Thank you, Artem
    Aug 2005
    Newton, MA
    Throttle body idle position sensor? I did open my throttle body a little to raise my idle a bit... I may need a new ICV and I do hav ea replacement... Its just a pain to replace it.
    Ill try closing it all the way tomorrow.
    -Artem
    Benneton (United Colors of)
    there's no point in trying to fix it if your car is only running on 5 cyls. mine only has a slight lump in idle (about 20-25rpm) and it affects the transmission.
  1. this is a strange problem
    Last Post: 01-27-2007, 12:58 PM
  2. strange problem..
    By peks in forum 5 Series BMW
    Last Post: 04-15-2005, 12:03 AM
  3. Strange Problem with 90 525im
    By Pwr2spare in forum 5 Series BMW
    Last Post: 02-11-2005, 06:47 PM
  4. Strange immobiliser problem..Need help!
    By V8_mac in forum 5 Series BMW
    Last Post: 12-20-2004, 02:57 PM
  5. Help! Very strange problem! Anyone seen this one?
    By Jeff N. in forum 5 Series BMW
    Last Post: 10-10-2004, 06:36 PM
