Should she be hissing at me??
Howzit guys,
Before I start with yet another problem on this poor car of mine, that I am really trying hard to get going. I just want to thank each and every single one of you that have helped me much more then I've expected over the last month or so. I really appreciate it and hope one day to return the favour.
Now on to the problem.
I washed and cleaned my car yesterday and did a few other things, she's shiny again and looking real good. So I turned the ignition on, I get "Coolant Level" or something similar, telling me she's low on coolant. So I open the radiator and as sure as hell, she's very low, so I fill it up to the COOL mark on the expansion tank. Go back turn the key again, she's still telling me she's low??
So I thought I'd let her idle for a while since I haven't had her running in at least a month. 20 minutes into Idle I quickly look at my temp gauge. And to my surprise she's hot, very hot. Over the half way mark! so I shut off the engine, and open the hood to check for leaks. I don't see any water dripping or leaking anywhere, except there's a hissing sound? like an air leak? I'm having a hard time finding where it's coming from, but this is definitely coming from the cooling system, somewhere!
So I go under and check, I see the bleed screw for the rad/expansion bit of the rad and there's like an overflow pipe. This is dripping water and looks brownish?? not too sure. Also the water/coolant had bits of dirt or something in the expansion tank not too sure on this either.
Now, would you guys suggest I bleed the cooling system? Is this hard? Also my old man tells me no matter how hard I try I won't be able to bleed her because it's a bitch to do and very very hard? Also he says it needs the engine running for 2 hours for me to do that? he then went on to tell me NEVER open then radiator cap once you've bled the rad or when ever as this will cause her to overheat again as it releases the pressure? now I was thinking, doesn't the pressure just build up again when engine is running?
I'm pretty sure it's because of this air leak or what sounds like an air leak that I can hear..
I'm really sorry to do this to you guys, I know you're all probably sick to death of my problems with this car. And thinking I should just get rid of her. But I'll admit it, I can't! Just got a soft spot for this car! and really want her back on her wheels/feet again!
As always, any help I would gratefully appreciate it!
Edit: I've got the bentely Service Manual. It tells me how to bleed the car, but it isn't very detailed about it. Could someone explain a little more for me please?
Car: BMW 525iA.
Engine: M20.
Trans: Auto.
Year: 1990.
