Hi everyone. I have a little deal that I will like to solve. i got a '95 525i, auto. The problem is that is leaking oil around the area of the dipstick goes into the oil pan. I replaced the "O" ring but the leaks continues. I tried a number of times just to find out that it continues to leak. The last time I took all the TB and brackets/hoses off the way to insure that the dipstick will go on straight and to avoit braking the ring. Also check the oil pan for any burrs that could cause the seal to fail and found nothing. Installed the ringwith dipstick tube, with plenty of lubrication and assembly everything back together. Lasted about two days before it happened again. Have done this same procedure a number of times just to end up with the same result. Is there something I'm missing or is there a trick to this??? I even smoothed out the dipstick where the ring seats to eliminate any possibility, to no avail... Any sugestions??? TIA, Dave.
