Results 1 to 5 of 5
Thread: ::.. Rotor Runout
    Default ::.. Rotor Runout
    what is the acceptable rotor runout? I checked my front rotors and one is about .001 and the other has about a 5 inch high spot .002.
    Slow and cold speed you cant tell but when hot and braking I get a shimmy to the max at anyspeed like from 100 - 30 mph.
    New front end parts and bushings, everythings new (ish) and tight.
    I ran the lugs tight on the rotors so thats not an issue and its clean betwen the rotors and hub.
    Are my new Brembo rotors fubared?
    Default .2 millimeters or .0078 thousandths of an inch is the
    maximum allowed checked out near the outer diameter of the rotor. I'd say your well within the limits for runout, I take the rotors off and look for hot spots and measure thickness at a number of points around it to see ifyou have any big variations in thickness.
    im sure somethings up with the high spot, you cant really cut these so should I be shopping for a new set?
    T·O·R·O·N·T·O
    Hey! Use a different delimiter You're confusing me. I use that to distinguish my posts at a glance without using Subscribed Threads lol!
    Hahaha...I like it tho.
    Quote Originally Posted by Qube
  1. Rotor questions
    By ahlem in forum 5 Series BMW
    Last Post: 03-22-2010, 08:29 PM
  2. Replies: 10
    Last Post: 06-29-2007, 04:46 PM
  3. Rotor replacement
    By ElNormo in forum 5 Series BMW
    Last Post: 12-04-2006, 03:29 PM
  4. Rotor Roundtable
    By Jehu in forum 5 Series BMW
    Last Post: 11-15-2006, 11:55 AM
  5. Rotor screw help?
    By angrypancake in forum 5 Series BMW
    Last Post: 10-25-2005, 08:43 AM
