Originally Posted by
Jon K
Booster-
Ballasts one per bulb, 2 D2S bulbs, 2 9006 bulbs.
Cut the **** out of the 9006 bulbs so that you can get the base off of it.... you literally dremel the hell out of the bulb, but keep the "ring" (plastic) that has the notches in it. Then, trim the D2S bulb so that the 9006 plastic ring will fit over, epoxy it so that the D2S bulb filament lines upw ith 9006 filament... you know have D2S bulbs rebased for 9006 sockets. Then just plug the OEM headlight connector into each ballast and each ballast into each bulb. Done and done.
