Its a common problem, usualy its the motor itself, roll down the passenger window, lean waaaaay over with one foot on the brake and the engine running. Shift into reverse while taping on the botom of the mirror, if it moves replace the motor. Make sure you get the correct part, the non-diping motor is different. failing that, next thing is to check the switch for it, my faulty memory tells me its next to the shifter, under the wood.
