Results 1 to 10 of 11
Thread: About checking auto tranny fluid
    Bay Area, CA
    Default About checking auto tranny fluid
    Hello,
    I know that for checking the auto tranny fluid, it is best to do it at a certain temperature. I read on the chart at bmwe34.net that the temperature is between 30 and 50C and they recommend doing it closer to 30C so it holds a little bit extra, but if you have no way of checking the fluid temp, how long should one let the car run?
    I just let it idle for approx 15 minutes. From experience, on a totally cold start, around what temp range would that bring it up to? Is it best to check it again later, but at a lil less idle-time?
    Thanks!
    Default Whats your ambient temp
    Quote Originally Posted by Hypr5
    Hello,
    Thanks!
    Bay Area, CA
    Approx. 55 degrees F
    Hockinson, Washington
    Im not sure on the exact time, but you will probably want to shift from reverse to nuetral to drive a few time. Driving it down your driveway might be a good idea as well. Sorry i cant help you on the temp thing
    Default I'm guessing that you have a dipstick.. if so then the
    dipstick should be warm to the touch but not uncomfortably so.Thats usually a pretty close estimate of the right temp with your ambient
    Bay Area, CA
    No dipstick. I WISH it were that easy. I'm tired of getting under there to check the fluid. It has a leak from the fill plug that I can't seem to get taken care of. very odd. have to check it frequently.
    Bay Area, CA
    Thanks for that advice, I didn't drive it, but I did shift through all the gears about 2 times. I just know that when its warm, even if it's a bit low, it will give a false "full" reading. I don't want to overfill it either, though!
    I want a dipstick in it. lol
    Bay Area, CA
    Also, since I'm really unsure of the temperature, how bad would it be if I overfilled the thing by a "few pumps" of the hand fluid pump. I imagine a pump is just 2 - 3 oz or so.
    Bay Area, CA
    bump before work.
    hyper,
    get the thing level up in the air very safely, make sure the car isnt gonna fall off if you have stands....
    get the correct hex to remove the filler from underneath... trans should be warm to the touch as you hold your hand on the trans pan, if its comfy its not hot enough, if its hardly bearable its the right temperature to unbolt the filler to check.
    Make sure you have the car idling, run with the brake on through all the gears and then put it back in park. Then go under and check/fill...it's a chore but with no leaks its good till the next 30k filter change.
  1. Replies: 0
    Last Post: 03-11-2009, 12:58 AM
  2. transmission fluid level checking procedure
    By shogun in forum 3 Series BMW
    Last Post: 02-21-2009, 05:45 AM
  3. checking trans fluid level in 530iT
    By Snidly69 in forum 5 Series BMW
    Last Post: 03-24-2006, 07:47 AM
  4. 5 speed auto...tranny fluid
    By baileydog in forum 5 Series BMW
    Last Post: 08-31-2005, 10:05 PM
  5. anyone run auto tranny without fluid and survive..
    By bimurtud in forum 3 Series BMW
    Last Post: 02-23-2005, 08:14 PM
