Results 1 to 10 of 18
Thread: ::.. How are these Rotors?
    T慈愛慈意愁慈
    Default ::.. How are these Rotors?
    Assuming these can be procured cheaply (read: less than $200 for front and rear), how are they? Any comments? They would be exactly these with no doubt.
    http://cgi.ebay.ca/BMW-E34-CROSS-DRI...QQcmdZViewItem
    http://cgi.ebay.ca/BMW-E34-ZIMMERMAN...QQcmdZViewItem
    Default They look like the have a bad case of termites
    Quote Originally Posted by Qube
    Auckland, New Zealand
    Slap me if I'm wrong, but arent holes bad - ridges good? I'm almost dead certain that it's posted here somewhere...
    Ridges and holes do well in the wet.
    Holes do better in extreme heat.
    All (esp. holes) cause more pad wear and deplete braking by however much material is missing in relation to the remaining surface that is in friction with the pad. And are harder to re-surface when they get worn.
    I use stock to avoid these pitfalls, I reckon they work a little bit better.
    I have them, I made a post awhile back about how they look, even has some pictures in it. I really should follow that up, I said I would....
    So far, I don't notice any more dust than usual. I usually wash my wheels about once a week (car too ), and they seem to have about the same amount of dust on them after a week as before, mabye slightly more.
    For the additional price over plain rotors, its definitely worth it for the bling factor if you have open wheels.
    I'll admit that there is no performance increase, at least in normal braking. They're supposed to prevent brake fade, but honestly, the only time I've ever felt brake fade in the E34 was when I went from 70-0 over and over again to find out how much braking it took to induce brake fade. Took 3 or 4 times. I've autocrossed with stock rotors and didn't have any fade there either. Then again, I wasn't the fastest guy on the track.
    Oh yeah, don't notice any more noise either.
    That help?
    New Milford, Ct
    The prev owner of my car had x-drilled installed in rear about 3k miles before he sold car to me. When I inspected the brakes the pad thickness and rotors were in spec with good wear pattern (zimmermann and pagid). Last week, I noticed that the pads are much thinner, and this is after about 5k miles of ownership. Before last week when I did rear brake maint., the rears were slightly squealing. I did the front brakes the day I got the car, Brembo OEM rotors and Raybestos pads and they have held up terrific since (very little dust).
    Keep in mind that braking power is distributed about 85-90% front, the remainder to the rear. And I have this much wear occuring with rear only b/c of X-drilled feature. My opinion - they eat up pads.
    I thought of doing x-drilled/slots for the front next go around, but might reconsider this. If I really want bling factor, I'll just paint the calipers.
    I have searched ebay for rotors and am curious - are the ebay stores selling original Brembo/Zimmermann/ATE rotors or are they selling built-under-license to spec rotors?
    Support your American Flag Merchant Marine
    No BMW at this time, eyeing a 91 318iS. 00 Saab 9-5, 89 Bronco XLT, 05 Kawi Z1k, 00 Ducati 748S Bip
    T慈愛慈意愁慈
    Well I have the Privat Kraftwerk wheels so I'm thinking full calipers AND x-drilled rotors... but if I'm going to be spending a fortune in pads I'll decide in about half an hour.
    Default Actually i think its the reverse. The old theory used to be
    that outgasses under extreme conditions built up a layer of hot gases between the pad and rotor and that the drilled holes allowed a place for these gases to escape. But the reality, or at least my version of it is that any time you drill holes in rotors you lose thermal mass which is needed to absorb heat generated by braking, the more thermal mass the less chance of boiling the brake fluid and having brake fade... Thats why i can't understand these people that put the bigger rotor with the most thermal mass and then drilling it full of holes....
    Quote Originally Posted by DanDombrowski
    That help?
    Interesting viewpoint Bill. Surely the extra surface area would help to sink the heat back to the air swirling round the rotors though... tho not much during braking I guess- I suppose that's when the thermal mass counts most...
    T慈愛慈意愁慈
    Okay so I'll get them. Any other hardware I should get at the same time? Nuts and bolts?
  1. Rotors
    Last Post: 11-13-2006, 05:27 PM
  2. Replies: 8
    Last Post: 09-03-2005, 02:46 PM
  3. Rotors
    By scottiej04 in forum 5 Series BMW
    Last Post: 10-20-2004, 06:54 PM
  4. Rotors
    By spitfire in forum 5 Series BMW
    Last Post: 10-19-2004, 08:54 AM
  5. best rotors to buy???
    By chris 540i in forum 5 Series BMW
    Last Post: 04-21-2004, 06:59 AM
