1. Check the fluid level in the tranny by the exact procedure in the manual.Originally Posted by GoldenOne
2. If not that, suspect your guibo (if it has one) or the centre bearing (in the middle of the drive shaft). Noise comes from the area just behind the front seats (but under the car).Nick
* beware- perhaps it is just the heat shield loose on the cat or between the exhaust and the drive-shaft, or the drive shaft tunnel and the body (tho these are usually a very tinny rattle).
3. Make sure you change your tranny oil and filter regularly, if you don't it will die, don't risk it so always assume any Previous Owners did not. It is perhaps a good idea to do diff and brake fluid at the same time if at all unsure.nick
