m
m
Wonder if anyone can help a newbie with a bit of a problem?
I'm half-way through removing an M50 engine from a late 95' 525i that I'm going to put into my E30 Cab.
Getting the engine out is the easy part but I'm having problems with the EWS system .
Q1. After an hour of scratching my head & getting nothing but splinters in my fingers, just how do you get the small loop aerial off the ignition key barrel?????
Q2. Where are the EWS II module & the TX/RX module fitted in the car?
Hope someone out there can help.
Many thanks
Iain S
m
m
Many thanks Bill R. I owe you.
Iain S
Is the donor a US car? Doesn't sound like it.
Anyway, the ring antenna usually breaks as it comes off -- not that expensive to replace, however. Just slides right off once the plastic cover is out of the way. And it might behoove you to find a US M50TU harness/dme so that you don't have to worry about EWS.
best, whit
Hi Whit.
Sorry, I should have said donor is a Euro car (easier to get hold of over here in England).
I'm not too worried about cracking the plastic surround but I was getting a bit paranoid about damaging the actual antenna.
Thanks for your input. It's much appreciated.
Iain S
Sure thing. But the antenna will still *probably* break. I know it's possible to get them off in one piece, but I've personally not done it yet (and I've removed a few of them).
best, whit
Typical is'nt it. You spend hours on a problem & finally get a half decent answer (thanks guys) .
Then someone comes along with the proper solution. See the link below.
http://evansweb.info/articles/2003/0...on-lock-barrel
Take the barrel out & the loop antenna should just slide off the back undamaged.
HTH someone else out there.
Iain S
