Results 1 to 10 of 10
Thread: Rocker Arm Bushing
    Seattle, Wa
    Default Rocker Arm Bushing
    M30 Engine:
    Could someone please point out the rocker arm bushing in this diagram:
    http://www.realoem.com/bmw/showparts...88&hg=11&fg=25
    Thanks
    Jim
    part number 21
    Jul 2004
    Quote Originally Posted by JMI
    M30 Engine:
    Thanks
    Jim
    The bushing is embedded into the rocker arm in a form of a steel cylinder with an opening for the rocker shaft.
    deleted air conditioning
    For some reason I have a memory that the bushing was available as a separate item that could be replaced by a machinist. I have always just replaced the entire rocker, saves alot of downtime and elimates the chance of poor work.
    Default Define bushing.....
    and what is the purpose? What are you trying to looks for/accomplish. Bushing is probably a bad term to use in this area.
    As the others have stated....easier to just buy the new rocker arm and avoid taking a chance.
    M30 Engine:
    Thanks
    Jim
    Jul 2004
    Quote Originally Posted by Scott H
    I think he is refering to the statement in Bentley repair manumal that says something like "check the bushing of the rocker for roundness"... that bushing is steel crescent that comes in contact with the camshaft - it has to be perfectly smooth and perfectly round.
    Default He's referring to the internal bushing inside the big hole in the
    rocker arm, bentley's states to inspect blah blah blah, Most rocker arms use a bronze bushing pressed into the bore of the rocker since steel on steel isn't a good idea usually.. but in this case bmw doesn't sell the bushing separately only as a complete unit in the rocker arm, pressed in and honed to size.
    quote=Scott H]and what is the purpose? What are you trying to looks for/accomplish. Bushing is probably a bad term to use in this area.
    As the others have stated....easier to just buy the new rocker arm and avoid taking a chance.[/quote]
    Default You wouldn't call that a bearing?
    and yes I would think it has to be smooth and round. I replaced all of mine when I rebuilt my M30.....the pads were worn enough to warrant replacement. What I was trying to get at is the problem JMI is looking for.
    Quote Originally Posted by Rustam
    Jul 2004
    I would not call that a bearing because it bears nothing... The rocker in fact, is more of a bearing for the bushing itself since it holds it.
    I did not bother checking neither the bushing nor the crescent pad. In North America - BAVAUTO.COM - charged 14.99 per rocker in Summer 2005... 12 nice rockers - end of the story.
    Seattle, Wa
    Thanks everybody.
    Yes I was referring to the statement in Bentleys
  1. m20 Rocker arm
    By bmwrp8 in forum 5 Series BMW
    Last Post: 12-10-2008, 09:53 PM
  2. Just had my rocker panels painted, what do you think?
    By nuclearfusion in forum 5 Series BMW
    Last Post: 12-04-2007, 09:44 AM
  3. Busted Rocker
    By dave.o in forum 5 Series BMW
    Last Post: 10-17-2007, 07:06 AM
  4. m20 -- rocker arm question (and more)
    By [1990]525 in forum 5 Series BMW
    Last Post: 09-25-2007, 09:12 PM
  5. Help Please!!! Rocker arm shaft
    By clhorton in forum 5 Series BMW
    Last Post: 09-22-2007, 09:07 AM
