Thread: oil canister check valve spring repair
    Default oil canister check valve spring repair
    My '90 535ia has the common low oil pressure light syndrome, so today I'm gonna inspect the pressure sensor and oil canister anti-drain check valve.
    Within the past couple of months somebody posted some excellent pictures and procedure for repairing the spring that controls the oil anti-drain check valve. I've searched the archives, to must be using the wrong key words, so cannot find the post.
    The procedure involved the anti-drain spring that keeps the oil from draining from the oil filter.
    Can someone please direct me to that excellent post and pictures of this procedure?
    Default Your probably thinking of Bruno's page as seen
    Here
    Quote Originally Posted by Dash01
    Thanks, Bill, but it was another posting. It had pics of the internal spring and retaining tabs, which must be bent to extract the spring.
    As I recall, the gist of the posting was that the spring loses umph over time, allowing the oil filter to drain back into the crank case. This was on Rennlist perhaps a couple of months ago.
    Anybody?
    Default Found it
    The excellent article on oil drainback valve is on Shogun's E32 fixes, which is well worth reading for anybody who has low oil pressure indication.
    link it!
  1. OT: Valve spring seat modification
    Last Post: 09-17-2009, 03:24 PM
  2. door lock repair - broken spring
    Last Post: 04-25-2009, 10:27 PM
  3. wtb good valve spring compressor?
    Last Post: 09-17-2008, 12:34 PM
  4. purge valve---charcoal canister
    By krazy00kanadian in forum 5 Series BMW
    Last Post: 06-28-2006, 09:52 PM
  5. Valve Wear and Spring Orientation
    By Hector in forum 5 Series BMW
    Last Post: 03-25-2004, 04:19 PM
