Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: BMW Coolant and Camshaft seal question
    KL, Malaysia
    Question on timing belt for M20. How long will it last, meaning how many kms/mls would it go before replacement. Here, in Malaysia, we are told to replace it every 40,000 kms which i feel is way too short a time. My other cars, Honda, Merc need timing belt replacement every 80,000 kms.
    Is this true ?
    H Mayer
    KL, Malaysia
    On coolant, we use bmw coolant from Germany. But the combination is not 20gal coolant/20gal distilled water. The mechanics here use tap water with just 1 or 2 litres of coolant. How will it affect my engine cooling system. No overheating so far in our hot tropical climate.
    H Mayer
    Default That may explain why I've changed the pump...
    twice in the 6 years I've owned my m30.
    if water pump is GEBA brand id exchange it, they suck, the bearings crap out usually in a year or less, we had to eat a lot of water pump jobs because of those turds, m50/20/30 all have died not just one model of pump, the one on my 90 325is took a dump with 37k miles on it in just over two years
    Philippines
    Well, it's supposed to be about 80,000km... but most people recommend 70,000 or even 60,000km. Just to be safe. 40,000km does seem a bit too short a time though.
    Near San Francisco, CA, USA
    Default Change all accessory drive belts, too, because...
    they must be removed to change the timing belt.
    Quote Originally Posted by jplacson
    Ok, planning a timing belt chage soon too... what parts NEED to be changed if this is done? Is it just the blet and seals? If my coolant is new, do I need to throw it all out and get new coolant?
    I checked bmwe34.net, but do I need to change those parts? Or is it just recommended since it'll save time?
    baton rouge, loserana
    i do them every 50k miles, not sure how that converts, as for coolent mix straight water cools best but has no corosion protection, coolent helps raise the boiling point also, i run a 50/50 mix but i wouldn't be worried about a lower ratio, as long as it looks good and green and it doesn't get too cold in winter
    Quote Originally Posted by bal3056
    H Mayer
    Atlanta, GA
    Default 50k miles is about 80k kilometers.
    Bloomsbury, NJ
    Default Awww shee-it...I was hoping you weren't gonna say that (m)
    ...when I replaced my pump a few weeks ago, it was a spur-of-the-moment decision (read as: hadn't ordered any of the parts yet), so when I called my stealer, he quoted me $118. When I got there, it rang up as only $68 (a substantial savings). Upon inquiring, I was told they only had re-man'd OEM pumps in stock (the jack-ass I spoke with had quoted a "new" pump even tho they didn't have any) and that they've had excellent luck with them. Those friggin' a-holios.
    If I have to replace this damn thing (along with all the belts) again in a year or less, it's going through their showroom window.
    Thanks for your feedback Winfred!
    Tim G.
    '91 535iM
    i wouldn't waste the money on a reman pump, what do you save $10-20? and when it takes a dump sometime in the next year you have a nice lifetime warranty so you get plenty of practice replacing it, i get a lot of customers who got tired of replacing lifetime warranty parts that come to us and get a factory part.
    as for what to change on a m20 t-belt job, belt, tensioner roller and a water pump, if you feel lucky skip the pump, i like to at least change it every other belt, but if it goes you get to do 80% of the same work to go back in and do it. generally the oil seals are ok on bimmers, the front crank seal is a bitch because the 22mm bolt is so tight it usually takes 3/4 drive tools to remove it and a way to keep the engine from turning
  1. Question about rubber seal around parking lights - front
    Last Post: 01-08-2007, 01:42 AM
  2. Camshaft Question
    By Kobe Diesel in forum 5 Series BMW
    Last Post: 10-18-2006, 10:09 PM
  3. Help with Camshaft seal installation.
    By DanH in forum 5 Series BMW
    Last Post: 01-21-2006, 02:37 AM
  4. Coolant question
    By E34 530 in forum 5 Series BMW
    Last Post: 12-31-2005, 09:23 PM
  5. sunroof rubber seal question
    By kentish in forum 5 Series BMW
    Last Post: 09-15-2004, 12:58 PM
