Results 11 to 20 of 21
Thread: Fixed the valvecover leak, stalling - now more problems.. GRRR
    Aug 2005
    Newton, MA
    will try to pull the plugs in a sec.
    -Artem
    Aug 2005
    Newton, MA
    Ok... the coils seem fine - engine turns on differently when i use differnt plugs... As in when i remove one it will be different than before, in some cases - it even stalls, so yea... Idle is still pretty rough. Not as rough as with some of these plugs removed, but still rough.
    What else can it be?
    -Artem
    well if the plugs all look the same the next option would be to either do a compression test or pull the valve cover and see if anything is broken, it still would be nice to know what cylinder/s are not firing first.
    Aug 2005
    Newton, MA
    Well, I can get some known working coils today (part number is the same, off an E34 540I). Would I be able to stick them in there and solve the problem, if thats the case?
    All of the hoses are connected and the car is running fine. I pulled the fuel rail though to remove the intake manifold. Could that cause anything? - Injectors/fuel rail? It was running better before i replaced all the hoses.
    I know for a fact valvecover is fine, nothing is broken underneath it, compression test was done a few thousand miles ago and I havent done anything that would affect/alter its outcome.
    -Artem
    Aug 2005
    Newton, MA
    Got it - the spark plug in the cylinder 4 has no activity - i pulled them one by one to clean then and to see if thats causing it . I do not know if its the coil or the fuel injector or what, but cylinder 4 is the problem. I really hope its not the injector... I donkt know what to do in that case. They should be all working..
    -Let me know if anyone has any more ideas now that the "quiet" cylinder was found...
    Aug 2005
    Newton, MA
    PS - I swapped the coils a few times... so if i got extremely lucky and got the same coild on there, thats it - othervise, im pretty sure the coil on there is different, and they it prolly works.
    -Artem
    Pop in a new plug first to be sure that isn't the problem, if not I would go the coil pack.
    Aug 2005
    Newton, MA
    New plug popped in... Plug was fine... Gettn new coils tomorrow.
    -Artem
    Benneton (United Colors of)
    vines ebay store will sell you a used fuel rail with 6 M50 injectors plus FPR for $30, a bad injector isn't that bad financially. you can test them by listening to them for the click and hooking a noid light up to the wire harness.
    Aug 2005
    Newton, MA
    Great! If the coil thing doesnt work out ill get the injectors then.
    Thank you all
    -Artem
    Ill keep you updated tomorrow if the coils solves it..
  1. fender bender grrr..
    By bmwrp8 in forum 5 Series BMW
    Last Post: 07-13-2008, 04:39 AM
  2. Oetiker clamps + CV boots = grrr
    By Jeff N. in forum 5 Series BMW
    Last Post: 03-05-2007, 02:45 PM
  3. Replies: 17
    Last Post: 05-15-2006, 02:55 PM
  4. 540 stalling
    By digitaldragon03 in forum 5 Series BMW
    Last Post: 03-09-2006, 03:39 PM
  5. Control Check fixed/not fixed??
    By Ian Dodd in forum 5 Series BMW
    Last Post: 03-29-2005, 04:33 PM
