Is it firing in all cylinders?
Alright, I fixed the valvecover leak and replaced all the hoses in the car, as well as ****in around with the ICV. The car runs now, though it was not starting for a bit - found out that some of the fuel injectors werent connected, hit the contacts to the injectors hard - they clicked in, and I was starting... now after that the RPM meter was through the roof - literally it was going past 8 and the 9k RPM... yet the car was acting like a normal idle, i reconnected a bunch of sensors and it is fine now. The problem is - when it idles and goes lower than 1k RPM in general it is very very rough... like really rough.. the car is shaking - i dont think it ever was like that and I can hear the engine when driving - couldnt hear it previously. I do have an exhaust leak but i am saying - more so than that leak. Does anyone have any idea what it is??
-Thank you, Artem
Cheers
Wingman
'89 525i/A Exec 193000kms
'94 Subaru Liberty AWD Wagon
Looking for Merc 300TE
NSW, Australia
Originally Posted by wingman
Thats what im worried about... it seems not to - how do i figure out which ones arent firing?
(Probably one of the cylinders isnt firing...)
Should I just pull coils one by one?
As in - is there an easier way to tell?
I didnt even know cars could run with a non-firing cylinder... Posts like firing on 3 cylinders seemedto me
-Artem
I have to bow out of this one as I run an M20. I would pull the plugs leads one by one on my car but it may be different on yours with the coils.
Cheers
Wingman
NSW, Australia
Yea, my car has i think 12V wires going into coils. The valvecover was leaking so i suspect one f the coils to be flooded with oil.
At least my fuel system is ok for now..
PS - Anyone with a parts 525I holler at me - I want to take a whole suspension off of one.
-Artem
Ok, today - tried checking the coils, but when i pull them the car just idles rougly as before. I have no idea what to do at this point. - Do I need new coils? do those things go bad? what can it be?
-Artem
Could it be the fuel injection's system's fault? anything?... Im really lost here - im even considering getting rid of the car and buying a civic or something...
-Artem
Keep the faith Artem. Don't touch that civic.Originally Posted by ArtemLepilov
I have seen people with frustrating intracible problems that it took a long to fix but with the help here, they worked it out. For example, Pyro had terrible problems with his car when he first got it. One of his early threads on had 56 posts and spanned 2 weeks and it doesn't even get to the end of the problem which is covered in another thread. The point is there is enough help here to get you through this if you can hang in there.
Example of the extensive help you can get here with patience
if you pull all the plugs, lay them in order you should be able to isolate the missing cylinder, then repost and well see what to do next.
Will try.. im running out of ideas here - my car starts and even drives.. but very very roughly - the thing shakes unbelievably, especially close to but under 1000RPM... I know one of the cylinders isnt firing, but what can I do to fix that?
-Artem
