Road speed regulated?Originally Posted by superkev525
Was driving in the rain last night and wipers started going mad on me. When you put the wipers on intermediate wiper they would work OK and then suddenly change to constant wipe? The same would happen when you put them on costant (i.e. vice a versa)any ideas? Wiper relay maybe? I have a 525tds touring.
Cheers
Wingman
'89 525i/A Exec 193000kms
'94 Subaru Liberty AWD Wagon
Looking for Merc 300TE
NSW, Australia
I have a '91 525i and mine see to be road speed regulated. Havent given them that much thought. Usually just use rain-x.
Aquapel works better.
Originally Posted by neil_004
I've never tried it. Still have a big bottle of the rain-x to go through.
Thanks for that guys ill check the manual on that one.
Might be that you need to reset the delay time between wipes, in the intermitt, setting,,,,,,manual sez how to do that-- flick the lever up and then down within one second,,,then flick up, then down again in the time you want the delay to be,,,then flick it up once,,,,it should (in a perfect world), reset to the delay you waited.
I think the process is a couple of steps quicker than this: with the wipers off:-
a) up then down (so, intermittent, then straight off again.)
b) up (into intermittent)
The delay should now be set to (roughly) the interval between (a) and (b). At least on my '93...
lol. At a stop, the time is doubled, because the rain doesn't accumulate as fast. As you speed up they will move back to the intermittent speed that you set. Also, on low....when you go below about 3-5mph, they will turn intermittent for this reason as well. High is the same speed always.
but the intermiitent is reset when you turn the wipers off.....seems that way on mine anyway
Gone but not forgotten
