You probably have tired stock components with 131k on them. The stock factory stuff will wear out by then for sure. If you want to stay stock, then get Boge shocks/strut inserts and replace the old stuff. A 3mm spring pad will not cost much and lower the front end a tinsey bit. If you are getting any vibration in the wheel at about 55 then you need new upper control (thrust) arms. Clicking going over speed bumps is usually the sway bar end links. It is cheaper to stay basically stock......but where's the fun in that!
Mike Holbrook
Meridian, Idaho
