Hi all,
So I decided to take Lowell's advice and swap out the brake booster / bomb to fix my brake problem. Lowell was right, the brake bomb was faulty. But after I put everything back, the speedometer/dash lights, and the climate control lights don't work. As in when I switch on the low or high beam, these instruments lights don't light up. So effectively, I can't see the speedometer at night. Had the fuses checked out and the mechanic says they're all good. Does anyone have any ideas on what may be wrong? A cut wire, or faulty switch perhaps? Any help is greatly appreciated. Btw, its a 95 520IA. Thanks in advance!
