Results 1 to 3 of 3
Thread: No heat when parked!
    Nov 2005
    Default No heat when parked!
    I have no heat on a 1996 328is when parked but the heat works fine when the car is moving. Could this be the water control valve? The car heats up normally according to the gauge. Any other ideas?
    baton rouge, loserana
    only seen that once on a e36 but the customer didn't want to spend the money on fixing it so i am not sure what that is, theres no pump on a e36 so it's not that, it may just be crud in the valve
    Ohio
    Default no heat
    Sounds like their is air in your system try bleeding it.. I had the same problem on my 90 525i
  1. Heat All The Time=Heat Valves?
    By slupregime in forum 5 Series BMW
    Last Post: 07-29-2006, 02:34 PM
  2. E34: parked ventilation question
    By Jobi in forum 5 Series BMW
    Last Post: 03-30-2006, 08:59 AM
  3. Aux Fan Wiped Out Battery While Parked..
    Last Post: 03-23-2006, 10:49 PM
  4. Parked ventilation upgrade
    By karimsm in forum 5 Series BMW
    Last Post: 04-28-2005, 09:33 PM
  5. Replies: 43
    Last Post: 06-16-2004, 05:00 PM
