Thread: Guibo & Vibration Damper
    New Milford, Ct
    Default Guibo & Vibration Damper
    Well I've finally started my project for the week. New exhaust, fuel tank replacement, guibo, center bearing, gearbox fluids. So here is what I find...
    The guibo is in bad shape, no problem since I have the spare to put in. But
    here is the vibration damper (attached file)
    The rubber in between the center piece and the outer band is torn up, for comparison it kind of looks like a sloopy beed of RTV. Will I get away with re-using this? A new one is about $250...I inquired about a week ago whether it is OK to re-install guibo without this. Otherwise, I might take my chances without it.
    Your opinions please...
    Support your American Flag Merchant Marine
    No BMW at this time, eyeing a 91 318iS. 00 Saab 9-5, 89 Bronco XLT, 05 Kawi Z1k, 00 Ducati 748S Bip
    New Milford, Ct
    Another photo of the damper showing the rubber that faces the transmission.
    Looks fine.
    New Milford, Ct
    The image for the last reply
    Seattle, Wa
    Hey Kobe,
    You a MEBA-District 1 Member?
    Boston & Attleboro MA
    A dampner that is not solid and stiff will cause the crank to wobble and throw crank codes and possibly you'll have engine cut outs.
    But I cant say from the pics if that would happen with yours.
    A BMW tech once told me the replace very few dampners, but when they do it's because that rubber seal is gone.
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    New Milford, Ct
    I think Im going to try my luck without it. Ive found on R3Vlimite.com that the E30 guys have been doing without the dampers, although it's a different design. I figure if I have problems without it, I can put it back it, that's not a problem.
    The pictures didnt come out too good. On side, the rubber looks intact, the other side it looks chewed up. I can push the inner piece in and out by hand axially, but cannot twist it radially.
    We'll see.
  1. Can a Guibo look fine and still cause a vibration?
    By Gearhead in forum 5 Series BMW
    Last Post: 09-22-2010, 02:37 PM
  2. Is my Vibration Damper shot?
    By baileydog in forum 5 Series BMW
    Last Post: 01-18-2008, 04:16 PM
  3. Vibration Damper E34 525 td
    By Tony777 in forum 5 Series BMW
    Last Post: 03-24-2007, 02:04 PM
  4. Replies: 0
    Last Post: 06-07-2006, 01:58 PM
  5. E34 540 damper replacement???
    By ben wilamowski in forum 5 Series BMW
    Last Post: 11-03-2004, 06:58 PM
