Results 1 to 5 of 5
Thread: Dashboard squeaks banished... yee ha!!
    Default Dashboard squeaks banished... yee ha!!
    This weekend I pulled my entire dashboard, primarily as the squeaks were getting to me, and I needed to setup the wiring for my cellphone adapter. I found out the squeaks (well more like creaking noise) were the cluster- so I sprayed the mating surfaces with silicone spray (around the outside of the cluster) and that shut it up completely. I read online some time ago the dashpad mounts squeak; they are metal clips that locate into metal brackets on the firewall below the windscreen. I fitted some pvc tape in there to ensure they are quietened just in case but I doubt they were squeaking. It was no simple job but all in all not bad. I'll be quicker next time as I get how the thing goes together now. The way they design these cars is great functionally but they leave a lot to be desired in terms of build smarts- things like removing the console requires removal of the handbrake lever (as well as the boot and handle etc.) which left me incredulous- it was unecessary work if they had designed the console better. There are examples of these sort of things elsewhere too, whether it be difficulties in removing rocker cover or replacing a water pump or distributor on an M30 due to tight clearances (and many other things). That being said I love things like the way the doors lock design, the steering wheel not coming off unless you have the key in the ignition and all those things that would have taken so much thought when you weren't in the business of copying someone else like so many manufacturers.
    I have yet more pet peeves after this job to add to those pesky T20 torx head bolts they love so much that strip on sight (with every T20 head I have ever had (even German ones- yesterday was one on a door-handle, the time before that there was the allen key on the rotor button which had to be ground off...). Then there are all those exploding clips on the all the electrical connectors; they look nice but are plain overdone and are just a bullet connector inside. Even if you goto the trouble of buying new ones from BMW you don't get the bullets, and (of-course) they are a right-angle type which I can't find anywhere... it is as if every connector on this car is made from the worst plastic and is completely unique. Is this what some point to as planned obsolosence? Nick
    Still haven't solved my problem of the indicator stalk not disabling automatically after turning left (the mecho works fine when you pull it and operate it manually) so I'm having trouble stumping up for a replacement...
    Sep 2005
    Goulburn Australia
    Quote Originally Posted by genphreak
    it is as if every connector on this car is made from the worst plastic and is completely unique. ...
    Then add 15 to 16 years in the Aussie climate and you have a nightmare. If you have to take anything apart make sure you have a spare ready to go!!! I'm hearing you loud and clear.
    Cheers
    Wingman
    '89 525i/A Exec 193000kms
    '94 Subaru Liberty AWD Wagon
    Looking for Merc 300TE
    NSW, Australia
    Quote Originally Posted by wingman
    Too right mate. I'm thinking of grabbing an AMP catalogue (Connector specialists owned by Tyco Electronics that sell trhough RS and others)- they have waterproof connectors that are modern and really nice. I'm very tempted to buy a whole bunch and have a replacement for every damn connector I undo from now on...
    Nov 2005
    Sarasota, FL
    I said it in another thread as well, but whenever I do repairs from now on...I try to see what plastic pieces are involved and go ahead and order them. I have broken every cover in the engine compartment, the alternator colling hose, and numerous connectors. I'm guessing the Germans didn't plan for FL heat and she is a bit brittle. The upside is, my car looks newer everytime I work on it.
    91 535iA M30 Auto
    Born in 3/91 (The Bimmer, not me )
    120,000 Miles
    Pics soon--she is a work in progress
    Wichita, KS
    944s have the same problems with the turn signals, on those you have to replace the stalk and mechanism on the column.
    Matt J.
    '95 540/6- Jim C. chip, Bilsteins, B&B, For Sale!
    -Sold
    www.wichitabmw.com
  1. Replies: 8
    Last Post: 09-19-2006, 05:05 AM
  2. Brake pedal squeaks!
    By jolllibean in forum 5 Series BMW
    Last Post: 03-07-2006, 06:28 PM
  3. Dashoboard squeaks banished
    By genphreak in forum 5 Series BMW
    Last Post: 03-05-2006, 04:26 PM
  4. Rattles/squeaks- hate them!
    Last Post: 03-01-2006, 06:19 AM
  5. Dashboard Help
    By KingSix in forum 5 Series BMW
    Last Post: 05-12-2005, 12:36 PM
